Im working on my lighting project which will be used in the auto industry. How important is a driver?
Say I were to use an led which required a voltage drop of 3.65V. If I used 4 of those in series that would require a source voltage of 14.6V.
So a typical car alternator pumps out 13.5 - 14.5 V when charging and of course when the auto is off its a straight 12v. With thise setup even with the alt charging I am still within the acceptable range for the leds voltage requirements. Yeah when its not charging the leds will be producing slightly less but im not really concerned with that.
Now from my understanding leds last much longer when powered by a driver. Im just curious how much of a difference there is.
If we are talking about going from a 40,000 hr life to a 20,000 hr life then I dont see a need for a driver. However if it cuts the life down dramatically then I see the need to incorporate a driver.
Being that I have not been able to experiment I thought I would ask the led gurus here
thanks
thanks
