Then it dawned on me that the only thing a BRIGHT light would do for me is let me see what's about to eat me just a little bit better!
Yep. Hard to see a black moccasin with a 10 lumen flashlight.Down here we also have to worry about what you step on, like poisonous snakes.
Moonlight doesn't cut it in the swamp. :shakehead
I don't know if this makes sense, but when there is a good moon out and I'm not walking in really dense forest I like to be able to "feather" a low lumen light in with the moonlight - usually about 2-5 lumens of warm light. Often I've been in a scenario when the moon is out and I can make out mountain peaks 10 miles away. I can barely make out the trail I'm walking on by the moonlight alone. If I turn on 100 or even 10,000 lumens of light there is no way I'll be able to see the big picture as well. 10,000 lumens with a 1 million lux at 1 meter isn't near enough light to show the mountain peaks 10 miles away. In that kind of scenario adding 2 lumens the trail is helpful to not stumble and enables me to still see the mountain peaks miles away. 50 lumens though and my night vision would be shot and I would only be able to see the area lit up by my light.
Using high lumen lighting you move through the darkness confined within a small bubble. Within that bubble your vision is sharp, but beyond the reach of your light everything is black.
With low lumen lighting your vision isn't as sharp, but it's not confined within a little bubble. You can look out across moonlit fields and see the hills way across the valley.
Thanks everybody for the responses ! I guess I don't need a longer distance thrower to see over the next hill afterall. Maybe all the hype about all of the new 300-400 lumen lights makes me feel I am missing out. But from the general consensus, I already have what I need, or maybe find something with more spill..
Valmet62
Well, it depends. For navigating a trail that I'm familiar with 1 lumen is sufficient (SF Saint Minimus on lowest setting). But for trying to find my way in unfamiliar territory I like at least 200 lumens. And if your "woods" contain any critters that may be above you on the food chain (bears, mountain lions, wild hogs) I'd suggest you can't have too many lumens. For me, the Minimus on low usually does the trick, but it's always backed up by a M3LT CombatLight or a HoundDog XM-L, the latter mounted on a rifle.
+1On regular flat trails, I use from 0.2 lumens when it's real dark to 30 lumens when it's real bumpy. I might go as high as 50 lumens on rough mountain trails. I don't remember ever needing more than ~100 lumens to check out noises (no bears around here) and do remember my eyes hurt every time I go from 0.2 to 100 lumens, but I often use a lot more than that just to find out if there's a big puddle of mud ahead, only so I don't have to get there and turn back before I look for an alternate road. Of course, I always have something strong to play with, but for actual walking 30 lumens is plenty of light.
Then you need a G5!!
