Illum
I have several AC-AC transformers stored in a crate, some have multiple secondaries but I found one that has only a single secondary. input is two wires: black and white, no red...so its 120VAC, output is two yellow wires, which I presumedly as AC
Since these transformers by itself has no regulation, taking readings for OCV will vary alot than the spec. whats a way to "load" them down for a test? with DC, I built a small load using a series of high current diodes mounted on heatsinks, with contact pins per 5 in a string, assuming a fan is on nearby blowing at the heatsink I can test DC using 3V, 6V, 9V, and 12V loads...but using diodes to test AC sounds a bit scary, so should I use a rectifier bridge and a series of resistors? I have access to 17 ohm 150W power resistors, so heat won't be an issue
I figured since using line voltage it would be difficult to run LEDs but certain LED drivers have a better time utilizing stepped down AC, preferably in the 12VAC region
