You have to open up the lower half to access the driver.
Heat it up again like you (most likely) had to do to the bezel.
Hold the lower part and firmly twist the black inner part with pliers squeezed into the two semicircle vertical slots on the ID where the LED is.
The black threaded part should unscrew from the bottom. then you can acess the driver.
