How to make "ELLY" 1 Watt AA flashlight focusable
lightbug
To make your bezel refocusable, just do the following:
Buy a good roll of taflon tape(also called thread seal tape), it is normally used for water pipes and costs $1 or less.
Just apply a few layers to the threads on bezel. It will make the bezel tighter and also refocusable. You can twist the bezel to make the beam into spot or flood.
I almost don't see any RINGS on my Elly with the SSP4 U-bin led mod.
Will upload some pictures later tonight.
LB -
Does your Elly drive the LED to a full 1 watt ?? I measure 3.24 volts at 220 mA. That's only .7 watts :-(
Mike
I have no idea, but the light gives out about 60 Lumens for the first few minutes, then down to about 45 lumens after 40 minutes or so.
LB --
I'm working with lasers and my first Elly seems underpowered. I added 7 turns to the boost coil and got nothing. I'll have to test my other units.
Thanks - Mike
Elly1 with SSC U-bin Vs. Elly2 SSC U-bin
Elly with CREE p4 Vs. Elly SSC U-bin mod
