shdwkeeper
I thought I would put together an updated or a NEW, How To for Maglites Mods. When I was trying to do my first Mod I had to look through multiple articles and posts just to get everything together and then it was trial and error mode. Well so here it goes, this will be my first tutorial on this.
To get started here are some of the parts you are going to need:
Here are the parts I used for this Direct Drive mod:
-3D Maglite
-SSC P7 DSWOI or DSWOJ Bin - I have some of these left or check with PhotonFanatic's stock as well.
-P7 SSC HAIII Heatsink
-Alumina Adhesive - PhotonFanatic or local electronic store
-Artic Compound - PhotonFanatic or local electronic store
-22 or 24 Gauge Teflon Wire - look on Ebay since Mudman is out of 24 Gauge.
-UCL Lens - 52.1mm x 1.90mm
The first thing I did was lay out the heatsinks, LEDS, aluminium foil, Alumina Adhesive, rubbing alcohol, Q-tips, as shown in the picture above.
I then cleaned all the heatsinks contact points and bottom of the LEDs, with a Q-tip and rubbing alcohol so the adhesive would get a good bond as shown below.
and the bottom of the LEDs
Now before you epoxy this LED to your heatsink you probably want to cut the tabs a little bit off of the LED. Here is a before photo:
and after cutting the tabs with some small cutters
Cutting these tabs allows you to have a tighter fit with the reflector, it also looks cleaner when you solder the wires to the LED.
Now is the time to mix equal parts of the Alumina epoxy, which I do on aluminum foil.
Once the mixing is done spread a very thin coat of epoxy on top of the heatsink, enough to cover the bottom of the led. You DO NOT want too much here, because you don't want the epoxy OOZING out and making contact with your LED tabs and heatsink. Once you have the thin coat of epoxy down, its time to place your LED on the heatsink/epoxy and give it a little bit of downward pressure to make a good seal. I try and line the LED tabs up with the holes in the heatsink as shown below. This gets you in good position to solder the wires to the LED.
Let the LED sit for an hour on top of the heatsink so it dries firmly. That finished up this part.
Now its time to take apart the Maglite. Here are the tools to get started.
Mini Screwdriver and a 5/64" allen wrench
Take apart the Maglite as shown below and set off to the side.
Use the Mini-flathead screwdriver to remove the rubber cover
Now take the 5/64" allen wrench, insert it into the switch hole and loosen the screw till the switch becomes loose, then slide the switch out the bottom of the Mag tube.
Use the same allen wrench to unscrew the bulb from the switch and set these parts (not sure what you can do with these, backup parts for something else) aside as shown.
Now its time to remove the actual switch from the switch housing so we can modify the housing. Pop the switch and Negative contact out, with a small screw driver.
Now, this is where the fun begins:grin2:. I use a dremel to cut the housing, some people actually use a lathe which looks nicer. But, no one is going to see this housing once its inside the the Mag tube.
Now, we need to do the same thing with the stock reflector.
Once all the dremel work is done, its time to break out the soldering iron and get ready to wire the light together. Get your 24 gauge Teflon wire out and cut 2 lengths. The Positive side (Red in my pictures) about 5 inches, and the Negative side (Black in my pictures) about 4 inches. You can trim these to the right lengths once you put the switch back into the Mag tube.
Once you put the switch back into the new Modified housing, bend down the Negative strip as far as it will go. The positive contact is in the middle of the switch. I also pre-tin everything with solder so it makes connecting the wires easier when that time comes. Use flux if you have it, it makes soldering much cleaner and easier.
Now solder the two wires to the switch contacts. Once that is done, put the switch back into the Maglite tube and secure it with the 5/64" Allen wrench.
Now the part you have been waiting for. Solder the Positive wire "RED" to the "+" LED tab and the Negative wire "BLACK" to the "-" LED tab. How do you tell the difference between the Positive and Negative LED tab? The Negative side has a little hole in the top of the tab if you are looking down on it (See Picture #7 above)
Once all the wires are secured to the LED, its time for a quick test. Add your batteries into the Maglite and power it on for 2-3 secs by pushing on the switch. Once you have light, its time to put the Mag back together.
Before putting the heatsink and light back into the Mag body, make sure you add an even layer of thermal compound around the heatsink, so it transfers the heat evenly back to the Mag body.
Now push the heatsink back into the Mag body, some Mag bodies will be a very tight fit. In this case I use a 1 inch PVC pipe and place it over the LED and tape it lightly with a hammer to get the heatsink flush into the Mag body. Once the heatsink is down you will probably need to cleanup some of the Thermal compound.
Cleaned up from the above picture.
Now put all the Mag parts back together. I took out the stock lens and replaced it with a UCL lens.
Now put the switch rubber cover back on, add the batteries and tailcap.
Your Done........:party: Now light up the neighboorhood.
I hope this tutorial helps anyone out there, that is trying to build their first Mag Mod.
Cheers...
-3D Maglite
Cheers...
