I am building a light using 4 CREE X-REs and want to power them at 1.4 amps each from a Li-Ion battery pack. The pack voltage should be high as possible for the largest power density, I want about 4 hours burn time.
I bought the DX 1.4 amp AMC7135 1400mA Regulated Circuit Board and planed to put it in series with all the LEDs and 4 Li-Ion cells but then I realized the max input voltage is only 4.5V and Vf of the led is around 3.5, so in this configuration the driver would be faced with a much higher voltage than it is rated for.
I am not worried as much about cost as I am building a robust light, can someone please suggest the best driver and configuration to drive 4 XREs from LiION cells?
Thanks,
Brandon
Thanks,
Brandon
