kosPap
hi all! Just to day I received a 4xAMC7135 kit from KD but it was no it, the boards were assembled!
my purpose was to have loose 7135 chips for mods, but now I got to find a way to relaibly removing thme for REUSE....
My plan is to put a thin blade under the chip, unsolder the big pad while putting upwards pressure on the blade...just barely.....when the big pad is off I will have to just lift the board by the chip with tweeezers, heat the 3 "elads" simultanously so that the board will fall off....
Any other methods to? also I have an adjustable soldering iron that can go up to 60W....what is the preffered temp/wattage for this kind of work?
thank you....
thank you....
