Richie086
Hi folks,
Thought I'd post a great use I've found for two of my flashlights I've been using on my Ezip Mountain Trailz electric bicycle. What prompted this modification was due to how expensive high quality headlights are for a bike. Below is my solution to adding more uses for a quality LED flashlight and a 4200k 24 watt HID flashlight.
My Husky 2D 4 watt Cree, 200 lumen LED flashlight mounted and
ready for action. The flashlight easily snaps off the mount should
the need arise to use the crenellated strike bezel for self defense.
Hopefully that will never happen. The hot spot and spill produced
by this flashlight is excellent for a bicycle.
This is a photo of my 24 watt Oracle HID flashlight mounted.
The shear amount of 4200k light is amazing and basically
makes you as bright as any car on the road. You have to
make sure the light is tilted down sufficiently as to not
blind oncoming cars.
What made this possible was my Wald #40 Black steel
Flashlight Holder for a cost of $2.77 plus shipping. I
purchased it at Niagara Cycle Works, where I purchased
most of my bike accessories from. The direct link to the bracket is,
http://www.niagaracycle.com/product_info.php?products_id=35751
I mounted the bracket to a block of wood in order to raise the mount
high enough off the handlebars so as not to crowd my gauges. I also
used a spade bit underneath the wood and honed out a rounded section
for it to recess into the handlebars for a better fit.
Should anyone decide this is a great lighting solution for themselves and
adds this to their bike, please make sure you cover the contact areas of
your flashlight with electrical tape. If not, the steel fingers will scratch
into the body of the flashlight.
