Recently I started to use Li-Ion batteries. I have to confess I was/am really afraid of "explosion" or "vent with flame". I Bought 2 Ultrafire 17500 for my Romisen RC-W4, 2 Trustfire 16340 (RCR123) for my Romisen RC-N3 and a DSD charger, everything from DX. The first time I inserted one 16340 battery which finished charging at exactly 4.2V. I thought, this is an excellent charger. Then next 16340 charged to only 4.15 volts. The 17500 charged both to 4.15 volts. From what I have read here in the forum, charging Li-Ion batteries to 4.15V is good since the batteries live will be longer. Up to here the history was good. I remembered I had an old DELL battery and disassembled it to get 8 unprotected 18650 batteries. I inserted one battery into the DSD charger. I took 10 hours to reach 4.2 volts in the charger, but this didn't stop charging. Since I have read that Li-Ions can reach 4.25 +-0.05 volts I tought that would be good to let the charger continue (I was taking voltage reading every half an hour). The next time I took the reading the batteri was charged to 4.6 volts, so I removed it from the charger (it was an unprotected and old battery so I didn't want it to vent). At this moment I tought "well, this charged is not as good as I tought". A couple of days after I inserted one of the 16340 batteries I had charged before. This time the battery voltage reached 4.2 volts and the charger continued charging the battery. Since I wanted to see how efficient the protection circuit was, I left the battery in the charger until the voltage reached something close to 4.29 volts. I Removed the battery from the charger before it finished.
My point here is: Don't trust your WF-139 just because the first time you got the perfect charging voltage. Be careful Don't even believe that leaving the charger in a metallic surface is good. When venting the battery can jump far away and something can get fire.
