-U0017
U - First digit is usually an undesignated digit, but perhaps this is a U bin - 220 - 260 Lumens @ 1000ma - pretty respectable.
0017 - still working on it
Is the 0017 the number of parts ?
The coding is more like this:
LXK2-PW14-U000 (there shouldn't be any digits other than 0s in the last 2 places)
U- is the the luminous flux bin. (max of about 113lumens at 1.5Amps)
I think the ebay seller accidentally integrated the quantity into the bin code.
PW14-Pure (cool) white emitters driven at test current of 1000mA
LXK2- refers to luxeon K2 emitters
I can't remember which digit it was but I believe the 1 in PW14 tells you its a lambertian emitter radiation pattern.
The K2 TFFC bin codes go like this
LXK2-PWC4-0200, LXK2-PWC4-0220, LXK2-PWC4-0240, LXK2-PWC4-0160, and LXK2-PWC4-0180, the last three digits refer to the approximate luminous flux at a 1 Amp drive.
The final note: The old U bin flux bin is referenced for the old K2 and the Luxeon I,III, and V. It has a margin between 87-113 lumens. The new U bin for K2 TFFC and rebel emitters ONLY refers to an output at a given drive current between 220 and 240 lumens. At this point, lumileds has yet to release the 0240 and 0220 Luxeon K2 TFFC emitters. The emitters you got from that Auction are the older emitters (LXHL-PW14-U000 is the correct bin code)
