xiaowenzu
Banned
- Joined
- Sep 9, 2006
- Messages
- 637
Hi everyone! I've been reading on how to make one's flashlight more grippier, and I've came across the heat shrink method - wrapping a large sheath around the flashlight body then shrink it, or wrapping a big piece of rubber around it. While these two methods work to prevent slipping, it also spoils the aesthetic appeal of the light! I prefer keeping the metallic anodized look and feel of the Novatac, and I'm kinda allergic to big rubbery things!
Anyways, enough rambling… here's my way of doing it! As you can see there are two 1mm gap on the Novatac 120T (same with 120P) to allow for heat dissipation. And I happened to find 2 spare O-rings lying around, so what better use for it than to fill the slit! Heheheh
Tada! the subtle yet eye-pleasing result:
The O-rings are 16mm diameter by 1mm width…… but I believe a ~13mm diameter by 1.4mm would create an even TIGHTER fit, which sadly I currently don't have. :shakehead
Now it's even grippier than before, improving the low aggressive knurling. O-rings don't spoil the look and also doesn't affect the heat sinking in anyway. It's semi-permanent, and only comes off when you want it to, and will not affect battery changes at all. Now, please cheer for me!! Hooray! Mehehehehe
