Not too terribly long ago I purchased the Junsi iCharger 106B+ and I am still playing with it trying to figure it out, along with the logging functions and LogView software.
Today I was series charging 2 unprotected 18650 cells I recycled from a laptop some time ago. I discussed them in this thread: http://www.candlepowerforums.com/vb/showthread.php?t=223884
If I have the correct cells, here is the data sheet:
http://battery.sanyo.com/en/spec/ion/UR18650F.pdf
I have been using them in a 2x18650 P7 light, and they were pretty well balanced, better than .1V. So, despite the fact that I was charging them without a balance cable, I believe it should have been fine.
I set the charger for LiPo charge, 1.5A 7.4V (2S) and connected with my self made magnetic charging cables. 12ga wire approx 10 inches long, so next to no resistance. Approx 8-10 minutes in I heard the fan controller kick on and my lab power supply current limit kicked in, so I turned up the current knob until it FINALLY went back to voltage limit (13.4V). At that point it was drawing ~8 amps from power supply! According to the graph I am posting charge currents were also that high (minus I guess whatever the chargers electronics were using, negligible.)
Well, of course I terminated immediately, but, any idea what may have caused it? Luckily I was right there monitoring the situation.
Bad cells? Bad charger? User error?
