zamboniman
- Joined
- Jun 9, 2007
- Messages
- 31
One of the nicer things about incandescents is that you can run them on a square wave without a visible flicker -- the thermal mass of the filament acts as a better and more efficient filter than a capacitor would be across the leads of an LED.
So if you wanted to create a regulated incandescent light, could you get, say, a 12 volt battery, and feed a 6 volt bulb with a square wave with a 25% duty cycle (since doubling the voltage to a bulb quadruples the power)? As the voltage of the battery dropped, you could increase the duty cycle of the square wave -- this system would eliminate the problems of in-line inductors.
All you would need is an in-line MOSFET or IGBT and a microcontroller with a set of lookup tables (what duty cycle to output for a certain voltage input). Is there a discrete circuit that anyone knows of that could solve this problem? It'd have to be custom-tailored to a certain type of battery, though.
Lastly, is there a way to use some elastic material to isolate the incandescent bulb from shock somewhat?
