Identify 750 lumen MC-E 4 D-cell from Jaycar/X-Glow
Mr Floppy
Does anyone know anything about the X-Glow range of torches from Jaycar in Australia?
What's caught my eye is this one:
http://www.jaycar.com.au/products_up...arge_15007.jpg
Quote:
750 Lumen X-Glow CREE LED Powered Torch
A worthy new addition to the X-Glow series of CREE LED torches. Powered by a quad-die CREE MC-E LED that is able to punch out 750 lumens of retina-destroying brightness. This is the kind of torch you need for serious outdoor activities. Camping, boating, emergency rescue departments, police, military, defence against the living undead - you name it. The wall of light will turn night into day and then some. It's silicone gasket sealed at the lens and battery ends so unwanted water and other liquids won't seep in. Functionally extruded and bevelled at the lens end so you won't lose your grip. The torch uses a twist switch at the base to lower the chance of accidental engagement. High quality rugged aluminium construction finished in gun metal matte grey/black.
• Light modes: Off, high, low
• Output: 750 lumens
• Burn time: 8 hours (3hrs on max setting)
• LED Type: 1 x MC-E CREE X-Lamp White LED
• Requires 4 x D batteries
• Dimensions: 355(H) x 52(Dia)mm
I'm pretty sure that most of these torches are sourced from somewhere and resold under different names. Anyone know what that could be or have info on this one? This one is not in the stores yet and they don't know when they will see them according to one shop.
