Infrared flashlights
ank
Are there any infrared flashlights out there, except Fenix TK25IR ?
ank
$300 for 0.1W output?! So I guess the Fenix wins with 3W output at $100.
What devices can be used to see infrared, in the consumer price range?
I read that cheap digital cameras can do it if you remove the IR filter
MX421
Texas
Fasttech has a P60 drop-in for $7.51 with 5 positive reviews (5*).
Deal Extreme also has a P60 drop-in for less than $10 that has 22 reviews (also 5*)
Good luck
ank
Infrared.
I already have a UV 365nm light, Convoy S2, which is awesome :D
archimedes
CONUS, top left
Thank you, that's what I thought.
There are quite a few other UV-related threads, so let's stick to discussing only IR here ... :)
MX421
Texas
OOPs,
Sorry, i saw the post on the Nichia UV LED and got offtrack...revised original post with 2 P60 drop-ins.
milehigher
Any Canon or Nikon can have the sensor replaced for one that allows shooting visible light as well as infrared what you have to be carefull with is your glass, many lenses cant capture infrared properly , you can also take "regular" pictures and run them thru photoshop to make infrared visible by chenging your settings on white balance and a few other things.
milehigher
In many cheap digital cameras just play with tv remote well snapping away if you see it lightup your camera sees infrared I have a Sony that natively sees it , whereas my DSLR' S had to converted.
lebox97
illuminationGear
EagTac & SporTac has several models using the Osram 3.4w 850nm IR LED
(highest output IR LED AFAIK).
the IR output blows away any "3"-"5"w eBay/FT/DX lights.
Distance to horses is 225 yards, tree line is 1/4 mile.
(and note the light was pointed down to ground).
Nzg3RUIxNzJEM0Y1QTg2RUE2QjE6NzY1ZmM2ODZmNTViNGQwYTVmOTVkNTcxZGE4NWQwMjA6Ojo6OjA=
Cheers
KBobAries
Phoenix
the IR output blows away any "3"-"5"w eBay/FT/DX lights...
How do the EagTac & SporTac compare to the IR drop-in from Customlites.com? I think they're using the same LED.
Dan
