I just got this light because everyone talks about how well it throws. :thumbsdow
I just don't see the attraction. I tested it against my Fifthunit Kenbar which I've modded and frankly there is no comparison. The beam on the Kenbar has a tighter spot and throws WAY farther. I did a ceiling bounce test using my light meter and the Kenbar on high is exactly 4 times brighter. Its so bright that when you shine it at a page you can't even see the black print. Only light. I noticed one site said the XO3 puts out 82 lumens. Am I to assume that mine is putting out 328 lumens or are Inovas claims WAY beyond reality?
Its not a stock light. I put 3v rechargables in it to up the voltage as it was designed for 18650s. It also has a cree xre P3. Also I think I stumbled on a little treasure. I took the the reflector out of a 3watt brinkman light I bought at Target. It works very well with the cree and actually has a tighter beam than the tiros optic XO3. And all that while having much better spill. If you're a modder I would Highly suggest you try this out.
Also for those wondering they were both tested with fresh batteries. I have been running this light everyday for the last 3 months and the cree seems to be holding up quite well and that is with me putting freshly charged RCR123As in it every day. I like for it to be as strong as it can be at any given moment.
