ESR = Effective Series Resistance
Electronic devices such as caps and batteries all have a ESR
When a device is made, there is always a amount of resistance between the actual "guts" of the device and the terminals that protrude out of the case
ESR is not inserted into a battery or cap, its just part of the construction of the device; its like the transmission of a car - you can have a huge engine willing to pump out 300hp - but if you have a "wimpy" transmission; that power is simply not going to get to the wheels
While designing high eff switching power supplies, you need to pay close attention to "ripple current" going thru the filter caps, the ESR in the caps converts the ripple into heat; too much ripple and too high a ESR - leads to cap venting (a bad thing)
A battery can supply current to the circuit, but as you draw more and more current the internal resistance of the wires and plates inside the battery start limiting the amount of current that you can draw out of it - and current thru resistance -> heat
For example, if you used one of those small coin cells, that has 400mAh - you would be able to light up a small LED (Like the Photon Key chain)
But if you tried to lightup a Luxeon or a string of LEDs even thou you had the right voltage - the internal resistance of the battery would act like a resistor in series with the load and prevent you from drawing too much current, and quickly heat up the battery
Large car batteries have VERY low ESR, when my brother starts up his 460cu+.030 engine in his 9000lb monster truck, he needs a battery that can put out 600-800 "Cold Cranking Amps" to turn over that huge engine with high compression, if the battery had too high of an ESR that current would simply be generated in heat inside the battery - and we know what happens next
There are test equipment out there to check ESR on caps, but you can easily test the ESR of a battery by measuring the open circuit voltage, then applying a known load, and measuring the voltage again
ESR should be equal to Voltage-Drop / Current
Too high of an ESR can be the signs of a bad cell in a battery as well
Mike
www.inretech.com
