MSaxatilus
Guys,
I recently purchased a Pelican 7060 LED flashlight from one of our reputable CPF dealers and have been quite impressed with the light. Its really nice to have a docking station to recharge the light after use and knowing that it is ready for a full recharge at a moment's notice.
Yesterday, I ran into an interesting problem. The light was inadvertantly bumped off of my tailgate of my car and landed on asphalt. The light was on before the fall and was knocked off when it hit the ground. When I the light for damage the lens and body appeared to be in perfect shape but the light would not operate. I took the tailcap off and checked the battery and everything looked fine. I reassembled the light and this is where it gets interesting.....
The light will operate normally (on/off and momentary) with the sideswitch only, but the tailcap appears to be inoperable. If I switch the light on, I can then use the tailcap to switch the light off, but operation then toggles to the tailcap only. Meaning that I can use the tailcap normally (on/off and momentary) but the sidewitch is now inoperable. It appears as though instead of working in conjuction with one another, the switches now appear to only be effective if toggled between on another.
Anyone know what could have happened, or have a any ideas to return the light to its original operation? I have reached out to Pelican for a solution as well. I will post any findings I can dig up here.
If anyone else has encountered this problem, I'd be interested in hearing from you as well.
Thanks,
MSax
Thanks,
MSax
