So I work in plumbing and have used a variety of lights for work from malkoffs, surefires, the Milwaukee portable handheld lights etc.
Nowadays I find myself carrying a AAA maratac light, and a stream light strion switchblade.
What surprises me is that the strion switchblade. I'm not big on floods lights or even stick lights. But this one somehow checks all my check marks for lights that have proven useful for my work.
If it's dark in my area of work I could just hang it using its integrated hook hidden at the base. I could mount it on metal surfaces due to the magnetic base.
Bright at 400 lumens, has both bright white and softer high cri type light.
And A UV function that will prove useful once I start learning more and more about HVAC.
Also the Primers for PVC joints they have us use for plumbing can be noticed using UV light.
Small enough I could put it on my carpenters pants pocket folded up and ready for work.
My only gripe, well sorta just a bummer, is the battery. It's replaceable but proprietary. Stream light model battery with its stream light design. So I can't fit the battery on my normal battery carriers. But the light is rechargeable
Just thought it might be helpful option if anyone is looking for something like this light.
I found out about only because a co worker uses it.
Thanks for reading ! Have a good one everyone.
