wasabe64
Scott and I have been working together on a couple of projects, so I have decided to post this one with Scott’s blessings. The starting point was an ARC 1xAA twisty.
The goal: graft an e-series head to the 1xAA body.
Scott is still coming up with a name for the one. (I will refer to it as the Mini-e for the time being)
The base components:
E-series head (the LA spacing post has been bored out and the centre hole widened to 3/8”)
Custom eSink for HD Luxeon
Custom eCan 'wee-can /ubbthreads/images/graemlins/smile.gif
TV0J LuxeonIII Emitter
ARC 1xAA Twisty tailcap (bored out to fit a 123 cell)
MM+/WO
The standard eSink was made for a side-emitter and did not place the HD emitter far enough into the reflector, so a new eSink was machined that placed the emitter on a slight pedestal (also handy for centering the emitter).
The ARC 1xAA twisty was bored out to fit a CR123 battery.
The headspacing was critical for the –ve body connection and there was not a lot of room to play with, so a shortened eCan was machined from brass.
The assembled pill:
Beamshot at 5’, Mini-e on the left, McLux DB917/TX1J/S017XA on the right:
I know, I know, comparing it against a DB917 is overkill, but it was all that I had handy...
Here's a quick size comparison of the Mini-e:
L to R: E1e, FireflyII, Milky's Mini-e, ARC LS First run
It's the shortest one of the bunch. /ubbthreads/images/graemlins/grin.gif
Hopefully Scott can post some real (read: better) photos when he receives the light.
MM+/WO
The assembled pill:
