modamag said:Secur1: v1.1 battery tube (with tritium slot) are now available, please check the Payment thread.
Will that be the only upgrade option available to v1 XRE owners ?
modamag said:=== Draco Enhancements ===
1. Tritium slots will replace the round GID hole on the battery tube. Battery tube change.
2. Increase the number of rotation between the battery tube and LE. LE change.
3. Improved thermal path. LE change.
4. Maybe Seoul P4 compatible. LE change.
5. O-ring standardization. Same oring for all the junction to save part number & my whooping cost. LE change.
6. Drake battery tube.
7. SSC P4 Turbo Head.
Is that what I think it is?modamag said:=== Draco Enhancements ===
modamag said:Regarding the operation of burst mode for extended period of time with AAA Li-Ion.
You can as long as you used it as designed, holding the light with your hand to induce the liquid (blood) cooling affect then there should be no problem. If you're out skiing the outside temperature gradient is more than enough to keep it cool.
However, if you're in Arizona when the outside temp is 100F/38C I would not recommend you keep it on burst while sitting on top of your car. In such situation level 5|6 is much more appropriate.
This is a general rule of thumb that would apply to any light regardless of their size/batteries.
crewcabrob: Wow! going thru 2x cell 3x (effectively 6x cells) within a day, which is ~ 4-5 hrs of use. You really got to put that toy down otherwise I'll start getting flame mail your Misses.
After carrying mine for a few days, I am running into this too... No matter how much I unscrew the head (short of it falling off), in my pocket, it somehow manages it active itself and is never in the same mode I left it in. One time even the user set mode was reprogrammed to the lowest level. I've also had a few times I've taken it out of my pocket, and by simply touching the head of the light, it will come on for a split second and switch to the next level. Are there any slightly thicker o-rings available for this to maybe give it a bit more resistance to turning?crewcabrob said:I'm still getting used to the settings, and how it behaves. I never seem to be able to guess what level it will power on with, but it is very easy to adjust once I figure out where it is.
sideman7 said:After carrying mine for a few days, I am running into this too... No matter how much I unscrew the head (short of it falling off), in my pocket, it somehow manages it active itself and is never in the same mode I left it in. One time even the user set mode was reprogrammed to the lowest level. I've also had a few times I've taken it out of my pocket, and by simply touching the head of the light, it will come on for a split second and switch to the next level. Are there any slightly thicker o-rings available for this to maybe give it a bit more resistance to turning?
It's this function of the flupic that is the root of this issue. Not that it's misbehaving here, but it's the brief contact (a fraction of a second) that is being made that flips it to the next mode. I've actually watched it happen when I've taken it out of my pocket. I had a similar issue with my Exolion until I put a tighter o-ring on. This may result in a slightly less fluid motion when turning the head, but for a light that you are sticking in your pocket, it really needs about as much resistance as say an Arc AAA if you don't want it to turn on by itself.goldserve said:Well, only draco V2 will remember the last level it was in. Also, make sure to turn on the led AT LEAST 1second before turning it off to always start at low (version 1) or stay on current level (version 2)
The key is you need to turn it on AT LEAST 1 SECOND.
bray said:from my understanding, this run of lights that are shipping now have all the enhancements besides 4,6,7???
