Walt175
Thanks Kelly! That's what I was looking for. :thanks:
I would use lens, the beam is much more favorable.
yes they can be used but you will need something (eg hot glue) to keep the optic from floating since lens pressure will not be applied.
Check out the sandwich shoppe:are these still available?
A 20mm star sinkpad should work. The PTS2 was a little tight so test fit the stars and file them down as needed for a good fit.
