Jamie
Greetings!
this post is a bit long - tying to explain a bunch...
I am trying to construct VERY small IR LED packages for use on dancers for a real-time motion tracking/motion capture system.
I am by no means an expert in this world at all.
In doing a bunch of research on-line about LED's and what not I ran across "Throwies"
(LED taped to a CR2032 battery with a rare-earth magnet)
based on this idea I have been working with up to 5 HSDL-4220 (30° beam)
SO
I am trying to figure out how to make something else bigger and brighter -
limitations include:
No heat sink
(??? - unless I can figure out how to make it small and aesthetic and ok next to the dancer's skin)
[FONT=Arial, Helvetica, sans-serif]Voltage: 1.5V~1.6V
[/FONT][FONT=Arial, Helvetica, sans-serif]Angle: 15~30 degree
[/FONT][FONT=Arial, Helvetica, sans-serif]Current: 140mA, Peak(pulse): 700mA
Power: 200mW[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]or from the same ebay distributor:
a 3 or 5 watt LUMILEDS 'star'
[FONT=Verdana, Arial, Helvetica, sans-serif]Vf: 1.5V~1.6V
If: 750 mA
Dimension
Backplate(W): 19.9mm[/FONT]
any thoughts would be appreciated!
thanks
jamie
The continuous electrical specifications for them are 875nm center, max 100mA, 1.5V. At a 100mA the 4220 delivers 76mW/sr and 4230 delivers 150mW/sr (in the middle that is).
These work fine but the problem is that at a distance of 60 feet or so they end up being the size of about a pixel or two in the camera view and therefore difficult to track.
SO
No heat sink
Small Battery - button size - could move up to a CR2450 (3 volt, 610mAh)(or 2?)
the LED's I have found include a EDIXEON IR I
"can be driven at 700 mA or 1000mA and reach 280mW and 400mW"
http://ideacomponents.blogspot.com/2007/03/high-power-infrared-emitters-gain-in.html
OR
[FONT=Arial, Helvetica, sans-serif]from ebay a 200mW 10mm High Power InfraRed (IR) LED w/Triple(3) chips[/FONT][FONT=Arial, Helvetica, sans-serif]Voltage: 1.5V~1.6V
If: 750 mA
Dimension
thanks
jamie
