marinemaster
I thought Dorcy is coming out with a 1W LED drop-in PR2 base. Have not seen it at Target yet. Anybody?
Chris
Chris
GeorgePaul said:It's not a Cree. About $15 at Sears.
Maybe, but I just use it with my 2D as an emergency light and it works fine. And I like that, unlike the magled, I could use it with 3D and 4D lights.Illum_the_nation said:...even lesser heatsink space than the magled
carbine15 said:I miss the 4-die smjled PR2 drop ins...:sigh:
cratz2 said:True, but the Variable Power led only pulls about twice the current as the SMJLED does... 410mA vs 180mA (both from 2 C cells) and is whiter. Plus, the PR based SMJLED is driving it at the very edge of it's spec'd range, possibly beyond it while the Variable Power is significantly under-driving the 1W LED.
I just bought one tonight for $14.99 at the Sears store in Del Amo mall, Torrance, CA.Illum_the_nation said:$15? its $19.98 last I checked...
carbine15 said:Okay but how low will it drain a battery? My SMJLED PR2 will drain a set of D cells to .01 volts each and still produce a bit of light. I bet these stop at .5 or higher.
