[ QUOTE ]
gadget_lover said:
It must be rigged somehow.... I just put a tv1j (star) LuxIII on a pair of AA lithiums and only read 143ma. Puzzled, it should have been close to 300ma, as the lithiums provide 3.4 vollts when fresh and in series. I put it on a bench supply and found that it did not pull the requisite 350ma till it reached 3.61 volts. That's clearly a Vf in the K bin, not J.
I'm not placing blame anywhere, but if they don't get the Vf right, how close to the LUMEN output are they? Especially knowing that almost no-one can (afford to) check the lumens to confirm their claims. A more paranoid and cynical person might notice that they could probably inflate their claims with impunity.
Daniel
[/ QUOTE ]
Not clear to me at all. Your measurements are more consistant with an "L" bin Lux III. Remember that the Lux III binning is done at 700mA. Using your 350mA measurement of 3.61V and adjusting upwards using the datasheet value of 0.8 ohm for the incremental resistance would yield a value of 3.89V. Assuming that you took your measurement fairly quickly, this would need to be adjusted upwards by about .04V to 3.93V to match datasheet binning conditions [to account for emitter heating. Datasheet Vf tempco is -2mV/C though I believe the actual is a bit higher]. This places it squarely in the "L" Vf bin.
Now, let me feed your paranoia [you may need to adjust you meds /ubbthreads/images/graemlins/wink.gif ] Per the Luxeon document that describes their optical testing, AB08, the flux measurement is to +/-10%. This means that *theoretically* you could have an "S" bin that is 22% higher in flux than a "T" bin and still have full compliance with their measurement specification.
BTW, the tolerance on the binning Vf measurement is +/-0.06V so it is clear that your "J" bin was mis-binned.
