It depends on the light. Most lights have the emitter on what's called a "star", and you replace the entire unit. Some lights the emitter is glued directly onto a heatsink with no star, often due to limited size or to maximize heat dissipation.
In general you need basic soldering skills, and thermal paste and/or thermal epoxy.
Better check for the Star (if not sure, give us a Pic).
For starting it is much easier to swap when the led is mounted on a star.
See a how-to here:
"new" seoul left, cheapo original right.
1st pic defocused, 2nd with reflector in focus
PS, but that might be just my personal opinion:
if the led - mounted without Star - is of an actual kind (means: no old Luxeon, no cheap whatever-copy) but just an "old" bin, the possible gains do not cover the possible dangers. imho the outcome will, in most of the mods, be worse than the original setup. Effort does not cover outcome.
hmmm :thinking:
just checked what "C2H" means, thats a Dereelight, right?
Features a Q5 emitter already and will for sure be directly placed.
Forget it, the outcome will be worse and the chance something goes wrong is very high
btw: what and why do You want to win by swapping?
And with what led?
(why excatly this one?)
There is not even a real chance to really improve a Q5 (enough to gain something)
[edit]
while checking search and typing, You mentionned the led.
Already a R2, but those scratches ... difficult.
Are there imperfections in the beam?
I dont have such a light and am used to work with few space when modding,
but would not dare to start with such a small light
[/edit]
Why not just RMA it if it bothers you that much? Lot simplier, and more effective.
Did you contact them and ask for an estimate of how long it will take?
If you sell it, sell it in the Marketplace. More people who know more about lights will see it.
Also why didn't you post a pic of the light instead of the beam (well, if your reason was tha lack of a camera, that's understandable)? A light with a smooth looking but crapply designed reflector will have a worse beam pattern then a well designed buit slightly damaged reflector. And if you post a picture of the light itself we can see how much a problem it is and Dereelight can also improve their quality (they swing around here sometimes).
I clicked every link in that thread and all I see is a beamshot (a picture of what the beam coming out the front of the light), not a shot of the LED + reflector themselves (the things that create the light and the beam pattern you see).
Maybe you posted the wrong link?
