is there a rechargeable battery recomended for the fenix p1d ce
raggie33
*the raggedier*
im trying to find the best rechargeble battery for the fenix p1d ce q5.the one i have now dont fit.its a no name one
ummm, I am not sure what "best" means. However, my EDC is a P1D-CE-Q5 and I have to use a "3v" RCR123 cell to have all 3 levels of light available. If I use a "3.7v" RCR123 cell, then I lose the 3 levels, but the output is admittedly brighter.
As for whose RCR123 cells, there are many sources: AW, BatteryStation, etc. There are also Li-Ion and Li-PO4 cells to choose from. FWIW, I have purchased RCR123 cells from several websites, but so far I have been the most satisfied with the Powerizer cells from: http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=1641
because they have fit into everything I have tried. As I recall, the Powerizer cells were tested by Silverfox as well. I thought that the Powerizer Li-Fe-PO4 cells were too low of capacity to be useful for me, but that appears to be the reported problem with most Li-Fe-PO4 cells - lower capacity than Li-Ion cells. The Li-Fe-PO4 use a safer chemistry though. YMMV!
