Is there such a thing as a red Cree?
Daravon
I'm setting up a darkroom and need red safelight. LEDs would be ideal for this application because there is no chance of shorter-wavelength light escaping a color filter. I think one CREE or even luxeon LED would be fine for my small room. All the red LEDs I can find, however, are wimpy 5mm and other indicator LEDS. Any ideas?
Cree and others make nice high power LED's in red. Osram does a dragon in red and the price is quite reasonable. Nice tight pass band on them too.
I suppose I forgot to ask, but do you know where I could buy them?
I got the red Osram's from Digi-Key. I think you can get red Luxeon's or Rebels or K2's from Future. Others can chime in for distributors for Cree and Seoul. High power red LED's are used extensively by the transportation and traffic control industry and the supply is well established.
I don't know what you plan to use to drive these but keep in mind that the Vf of these is considerably lower than blue, green or white LED's and sometimes this may dictate a different driver depending on the Vin.
I ordered one of the ones from Dealextreme, but it never came. The rest of my order came and it a little slip that said the LED was backordered, but DX never emailed me a confirmation email so I can't follow up. First time DX let me down.
Edit: I found the email in my spambox; it says 'waiting on supplier'.
Digikey carries the red Cree LEDs, but the minimum order shown on their website is 250 for a total cost over $1000. I sent an inquiry yesterday to see if they can allow a smaller quantity, maybe with a surcharge. No answer yet.
I was at the local electronics surplus store today & saw some red Crees today. I automatically thought of this thread.
Said they had 45 of them in stock as of today. $8 ea. http://www.allelectronics.com/make-a-store/item/LED-109/1-WATT-RED-ULTRA-ULTRA-BRIGHT-LED/-/1.html
Link shows XL7090 mounted on a black MCPCB but the ones I saw on display was a XR7090 mounted on a white MCPCB. I didn't see any XLs there. I suppose you can call & ask which you would get if ordered online but I doubt the guys there will know the difference if you ask them about the package type. Or I can pick them up for you that way I can make sure you will be getting XRs. PM me if interested.
UPDATE: I got a response back from Digikey first thing this morning. They have the red Cree XR-C LEDs available individually. The part number is XRCRED-L1-R250-00M01CT-ND and they are $5.61 each. Here's the Digi-Key direct link to them.
I've got one of the dealextreme reds that Marduke linked to. It's running at 700mA and I have just tried it in a room 14'x8'. It easily lights the room enough to work by, if anything I'd say it's brighter than I remember dark room lights being at college but that's a long time ago.
Paul.
I just got my DX LED. It worked when I tested it with a AA battery and it worked when I tested polarity of a 12v 50mA wall wart by very very briefly touching the leads. Now it's dead. Never even got a chance to try it out full power. Do you think I killed it with the wall-wart? It's about 18v open circuit, but still, being a 50mA wallwart, I figured it would be safe for the briefest of connections.
For some reason, I am thinking that Cree red LED die are made by Osram. I am not sure on this, but it sticks in my head. Osram makes nice LED die.
As far as the walwart - some are AC of course. In any event, there are some wierd spikes when you turn things on - maybe this is what killed it.
My recommendation is the Lux III, as it can stand a lot of abuse and current range. It is not as efficient as the K2 version, but it can take tremendous abuse and current range.
Even 2 NiMH cells or a single CR123 can be used in direct drive, or add a 2 - 5 ohm resistor as needed.
This is the star version from the primary distributor:
http://www.futureelectronics.com/en...-emitters/colour/Pages/5118849-LXHL-LD3C.aspx
Yep, 12V will fry them every time. Wouldn't matter what LED it was.
Grrr. There was a resistor in line with it, the current was (supposedly) limited to 50ma. I never would have thought.
I'm still not sure I understand. If it's a 50ma current limited, then it's NOT actually 12v...I would have thought I could wire it straight up and it would just run at 50ma...I do understand that the inrush current could have fried my led though.
I re - read your post. You mentioned that you used the LED to test the polarity of the wal wart ?
Perhaps there is one more important piece of info you need - an LED (light emitting diode) is technically a diode construction, but actually is NOT a diode electrically as we normally think of them.
When I think of a diode, I imagine that it allows current in one direction and blocks it in reverse. That is sort of true in an LED, but not the way you think. In this case, electricity is "allowed" to flow in one direction. If you reverse the polarity, the "diode" is destroyed - instantly.
