I seriously doubt that it is an issue with the D2S,or most low wattage HID lamps, however the larger HID lamps are often VERY sensitive to orientation. For example in the 175 watt HID lamps (MRX/MVX series) there are actually different part numbers for base up, base down, and horizontal burning. Run the lamp in the wrong orientation and it either doesn't start, or has a seriously shortened life.
Let me quote from the GE large lamp catalog
"Mercury and High Pressure Sodium lamps may be operated in any burn position, and still maintain their ratedperformance specification. Metal Halide and Low Pressure Sodium lamps however, are optimized for performance in specific burn positions, or may be restricted to certain burn positions for safety
U=Universal burning position
HBU=Horizontal -15 degrees to base up burn
HBD=Horizontal +15 degrees to base down burn
HOR=Horizontal +/- 15 degrees
VBU=Vertical Baseup +/- 15 degrees
VBD=Vertical Basedown +/- 15 degrees"
Most HID lamps have huge design lifetimes, 10-20,000 hours, so in automotive and flashlight applications, they run out of start cycles before they run out of hours even if there is a sizeable penalty for bad orientation.
For example in 175 watt MVR series designed for base up,
you get 13,600 lumens and 10,000 hour life in Base up,
but only 11,700 lumens and 6,000 hour life in horizontal operation according to GE...
