It's official my Quad Cree Mag is royalty...Now with beamshots...
cqbdude
Kalifornia
My Quad Cree Mag has been Crowned...:laughing:
It's " Sir Quad Cree Mag " to you...:grin2:
This next picture was taken specially for PSM.....
Some people wanted beamshots...so here they are...Of course I had others lights for comparison..
Starting from the left...McGizmo 27LT Seoul, Sir Quad Cree Mag1C , Quad Cree Mag 2C and Tri Seoul Mag 1D
The Business end of the lights...
The 27LT Seoul on High about maybe 75 feet away from the Truck.
Sir Quad Cree Mag 1C 1 x 18650 with McR19 reflectors
Quad Cree Mag 2C 2 x 18500 with McR19 reflectors
Finally Tri Seoul Mag 1D 4AA with McR20 reflectors
Hope this help show the diffences between these mods..
Re: It's official my Quad Cree Mag is royalty...
nice job, what does it run on?
beamshots?
Thanks...Its running on 1 x 18650 Li-ion.....using a shark driver....
Wonderful looking! Can't you cram more than one 18650 in there though?
Its a Mag1C configuration so I dont think you can put more than 1 18650 .
I do have a Mag2C set up the same way and is using 2 x 18650 .
Raul, you're on a quest for the sun in your pocket, aren't you? :D Very nice setup. How about some outdoor distance beamshots please?
Very very nice dude :twothumbs...:clap:...:goodjob:
Best regards
____
Tom
Nicely done, are you running the XREs at 1A each?
What's the round washer like bit on the side below and behind the switch?
Salamat Pare,
I will get some shots for you when I get home tonight....
It's overkill to do it indoors...
Thank You Tom.....I love this light...small and light and bright...
Essexman...that washer thingy is where FiveMega installed a charging jack.
That way I dont have to take the battery out to charge it..
Lowtech....The Cree's are running a 900ma each...but it does drop off because of the battery limitation, its still plenty bright...
:drool:
Warn me next time! I'm telling ya, chrome lights AND scanners in the same pics make me all gitty! :rock:
Thanks for sharing!!
PoliceScannerMan said:
:drool:
LOL.....I will definitely warn you next time....and yes, there will be a next time....:grin2:
Well that's just an absolutely gorgeous light and an awesome build! The crown sets it off too...
Did you do the build yourself?
18650 Insert
I thought that battery tube would just pop right out! Wrong!
They will come out pretty easy for use with AW C protected battery and the charging plug still works. Mirage Man can cut the tail-cap down...
I did it the hard way on this one, no fun...
http://i15.photobucket.com/albums/a369/vdcjr/IMG_1622.jpg
http://i15.photobucket.com/albums/a369/vdcjr/IMG_1627.jpg
Cheers
Ouch....that didnt look like it was fun...
The tube will come out when you unscrew the charging jack, as you probably found out..
What are you planning on doing now?
Yes I did the mod myself with some help from modamag....
Thanks......
18650 Insert
Cheers
Have you considered hooking one of these up to run the LiIon "C" cells? Those are more like 3300mAh instead of 2200 -- should be good for at least 50% longer runtime, maybe more as I bet the "C" cells would not sag as much under load.
Thanks......
Yep, I found out the hard way! :)
I'm really not sure at this point. I was thinking about a triple Seoul or I have a 5w X3T laying around. I'm gonna pull the batt tube and have Mirage Man cut the tail-cap to fit an AW C.
How did you decide between the Cree's vs the Seoul's...
I'm interested in what you would suggest having gone through the Mod & having done it yourself, anything you'd do different...
Thanks
Yes...I have considered using C cells. But probably one of my other mag c mods..
This one will require more modification due to the way FiveMega set up the charging jack..
But I have 2 other MagC mods with tri and quad cree that I can convert to the new C cell...
And you are right it should help with the sag...
Thanks for the suggestion...
Lips....A tri-cree or Tri-seoul is the way to go...its simple specially if you are using stars instead of just the emitters.
I went with the cree because it was the emitter that I had..now that the seoul is more available, I would prefer it . It just depends on the reflector that you like...I have a tri-seoul that is using the McR20 reflector and will be making another one that uses the SMS20 reflector, its cheaper..LOL
Pm me if you have any questions....
