Jet-1 MK IBS problem
Ecko
I just received mine yesterday and I can't get it to max brightness. I get it to go through the brightness cycle from low to high, but this thing is no where near 225 lumens.
When I switched from a regular Duracell to an Energizer Lithium I saw no difference in the max brightness at all, and in the instruction booklet it says to use a Lithium to get Max brightness of 225 lumens.
This is the battery I'm using... http://www.amazon.com/dp/B00003IEME/?tag=cpf0b6-20
Is there something specific I have to do in the hidden menu for it to hit 225 lumens?
You need to use a 14500 3V battery to get the max brightness out of it. The lumen rating is rated using bulb lumen, not out the front lumen.
Hope that helps,
Flavio
BugoutGearUSA.com
14500 is Li-Ion cell, size of AA and 3,7V (4,2 freshly charged). Using Alkaline, Ni-MH or lithium you'll get about 130lm only.
To get the 225 Max brightness, you will need to get a 14500 3.6V battery and a charger for it. I got mine here: https://www.fenix-store.com/index.php?cPath=53_57
I recommend that you learn a little about Li-Ion batteries to avoid any :poof: situations. Here's a good place to start: http://www.batteryuniversity.com/
If we say that we have fellowship with him, and walk in darkness, we lie, and do not the truth. 1 John 1:6
