Howdy hairydogs,
I'm pretty sure that the series 1 uses AA size batteries, the series II uses CR123/RCR123, and the series III uses an 18650 lithium-ion 3.7 volt cell.
...except for the III-M, which is multi voltage using either an 18650 or 2 CR123s. There is also a new III Pro that is supposed to be multi voltage.
what are the difference in these three systems. I am confused. Jetbeam I use AA and Jetbeam III use CR123?
This thread is a start and was before the JET-III-M came out. http://www.candlepowerforums.com/vb/showthread.php?t=206250You're confused... have you discovered how many different Jet-I, II, and III's there are? :thinking: Hopefully someone will point you to an excellent post from a while back that tries to layout the differences.
Looking at other 2xCR123/1x18650 lights at http://www.light-reviews.com/ it likely has flat runtime on 2xCR123 while it has semi-regulation with 1x18650.Does anyone know if the 'Broad Voltage' (term from BugOutGear USA website) driver has an efficiency disadvantage compared to the 18650 only version?
