LightGiver
- Joined
- Oct 1, 2009
- Messages
- 28
First of all, the light was working fine for a couple of weeks, then it began functioning erratically. When I turn it on with the head tightened, it doesn't always come on in full brightness, it will be dim, or begin flashing bright. If I loosen it for the 2nd output, its either very dim, shuts off, or will flash dim then go bright and shut off. When I'm able to access the programing feature for the different modes modes on 2nd output, it won't retain it after the light is turned off. It will either resume erratic operation or continue cycling through modes. Anyone else experience a similar problem with theirs? Am I stuck in some kind of secret test mode I can't get out of or something?
