JetBeam pro-II help!!!
Treg
Canada(Québec)
Hi guys, I just got one and I'm having little problems programming it. Do you to get the light on and then slightly press 3 times to enter the program mode or do you do it while it's off??? Thank's Treg!!!
The instructions listed on the Bugoutgear page is for the reverse clicky. The JetIII has a forward clicky and you need to compensate for that. I have found that when the instructions say to click a certain number of times that I need to turn the light off, then click the required number of times and then turn the light back on. You must do that quickly for it to work.
Alan
Thank's guys, that's the way I came up with Alan. That's why I posted that question because the instructions I had with the light didn't worked...but in the end everything is fine. Thank's again for your input...Treg!!!!
