Just wondering... Duracell MN21/23 12V batt
Phaserburn
Connecticut, USA
I have a couple of these for a recently purchased Glo-Toob FX. My question is this: I know there's very little capacity in these tiny cells, but they are rated at 12V! Why can't Duracell or someone use the same alkaline technology and make a 12V D-sized cell that would be worth so much? I realize this may be a silly question to those who are in the know, but just wondering...
If you took apart one of these batteries, you would find 8 small 1.5 volt button cells inside, wired in series to provide 12 volts. I forgot what size these button cells are, but LR41 comes to mind here.
Ah, ala 9V batteries. No magic then, just packaging hocus pocus!
/ubbthreads/images/graemlins/frown.gif
Did you actually take one of these apart not knowing what was inside? That's fairly brave, I would think, chopping into a potentially acid filled shell!
By chance I took one apart last night /ubbthreads/images/graemlins/smile.gif. Confirmed that it's made of many button cells. They do look like LR41's, same dia. as LR 44 but thinner. Might be a cheap source of these for people wanting to overdrive torches which use LR44's. I did it with a LED Lenser copy I had lying around, and it is quite a bit brighter.
To paraphrase that guy from Bladerunner: to burn twice as bright for half as long....when I think of some of the 5Watt mods this quote seems quite apt: "And you have burned so very, very, bright, my friend"
Hope that made sense to someone... /ubbthreads/images/graemlins/icon15.gif
Brandon.
