KWillets
One of these came in the mail last night. Anybody else got one yet?
So far it's great. I put in a protected 18650 and it runs like a champ. It's a tight fit, however, and I'll have to dismantle it to push out the cell when it's done.
The main caveats are the shadow ring around the spot (which Kai warns about), and a flicker which cleared up after some exercising of the tail switch.
The low level (350 mA) seems comparable to an Elly (edit: with a Cree in it), with a tighter spot, and the high (700 mA) is quite high. It cycles through the modes.
The shadow ring is quite pronounced, and the spot also has some distortion, but not enough to be a bother. It's possible I overtightened the head while I was pushing in the battery; it's a plastic reflector.
I'll probably use this as a bike helmet light, replacing the Elly. The throw and brightness should give me about twice as much "spot reach".
