Whoah...$18/pair!
That's great, thanks! I went to Amazon and one of the prompted items below was [h=1]Cibie 82440 Round High-Performance H4 Fog Light[/h]It is clearly a 7" H4 headlight, but 57.96 is a good price
Whoah...$18/pair!
I just recalled (and the picture of the product helped that recall) that the envelope surrounding the high beam filament has the blue tint (although much more lightly applied) on it. This will cut into the high beam performance, but most driving is on low beams (sometimes erroneously on low beams, but low beams nonetheless).
Think I'll stick with the +100 then. While yes, most driving is on low beam, I do have some stretches (unlit/poorly lit interstate) where high gets used and would rather have the better bulb.
That's an excellent deal on the Nighthawk Xenon, which is an excellent bulb.
So I ordered the Phillips +100 bulbs and the seller substituted the +130 stating the +100 was discontinued.
Was this from Amazon? Filament tint aside, the +100's are also consistently more expensive than the +130's on Amazon, so if the seller sent you +130's at +100 prices, you essentially overpaid for them.
It depends on how anal you want to be about blue tint on the bulb. I prefer to have no blue tint surrounding a filament, because that always means less light reaching the road, but there's blue tint (partial/light blue) and there's blue tint (full/dark blue). The Philips +130s are good performing bulbs, and so are the Tungsram/GEs.
Bulbs branded "Hella" have never been made by Hella. They've always been private-labelled bulbs made by other makers. For a long time, they were perfectly good bulbs made by reputable makers like Osram and Philips and a couple of others. But starting about 15-20 years ago, they're mostly generic junk from "low-cost countries". Best avoided.
I don't know for sure if the XV 100s (sounds like a discount cigarette!) are discontinued. If I had those two choices in front of me I would opt for the GE +120. But if the gates were wider open and I wanted the maximum possible lighting performance, I'd hit up Dan Stern for the Osram 70/65w bulbs.
