old4570
I had to share this ........... This is so funny ! The best bit is at the end ( the knife is not sharp )
Well , I guess there might be 101 ways to get a knife sharp , is this really one of them ?
Quite a good deviceFor more sharpness he need to use more steps with sandpaper and smaller and smaller size
A more advanced version from a master from Canada
sharpened 120 grit stone grinding wheel and leather grinding wheel cleaning
I've never had any issues with sharpening M390/20CV/204P with standard diamond stones, finishing on pasted strop.
Same goes for S90V, 15V, R45 etc.
I sharpen them the same way I would 1095 on an Arkansas stone.
20CV is pretty much the same steel as M390. They are analogues, just produced by different companies. If you had no issues sharpening 20CV, then the issues with the M390 blade are likely not steel composition, but blade geometry or heat treat.I only have 3 diamond bars, 1 ezelap 21c and 2 pieces from FIT FINCH INDUSTRIAL TOOLS 400 and 600 grit
So far this is first steel that is difficult to sharpen. There are a couple of knives 440V (S60V) and several S30V, I used to have 20CV from Buck and 10V Spyderco, there were never any problems with them. But the main thing is that it led me to that site, at the same time I found out how to sharpen ceramic knives for my friend
We need more tests, I ordered a piece of good diamond 4*1", we'll see. It's a pity we're far away, I'd send it to you to look at20CV is pretty much the same steel as M390. They are analogues, just produced by different companies. If you had no issues sharpening 20CV, then the issues with the M390 blade are likely not steel composition, but blade geometry or heat treat.
