L0D on 10440... Any runtime informations/test?
I honestly have been a little nervous to do a run-time test. Since the only cells I could find were unprotected, I don't want to risk damaging them. I bought two cells and just swap them when I feel it's needed.
Finally bought a nano charger with 2 cells from AW. I'll see by myself! Someone said that the output difference was noticeable and that the cell wasn't overdischarged at the end of discharge.
The output increase is incredible!! I compared my LOD on li-ion to an LOP-SE on lithium primary, and the "primary" mode on my LOD was as bright or brighter than "high" on the LOP-SE. Unfortunately, you do lose your "low" mode. Technically not, but the lumens on "low" with li-ion seem to be what they were on "primary" before.
This is what I was guessing! The modes steps all of 1 level. Low becomes med, med becomes high and there's a new brighter high. I think PWM permit the use of Li-ION on the L0D without screwing the different modes. They are just all brighter! But as I said to someone, my guess that the runtime is decreased maybe by half (320 mAh compared to 1000 mAh). If I need lower output and more runtime, there's still the possibility to use NiMH but to impress and intermitent bright needs, Li-ION would be the best!
light_emitting_dude said:
Imagine what a 10440 will do with the new LOD CE!! 135 lumens like the L1D CE??
:D Thus for a light of this size I prefer the lower output of the L0D. On high it is bright! Medium is perfect for most use so low with Li-ION will be perfect. If I need longer runtimes or lower output, NiMH will be the way to go.
