Has anybody tested the new Fenix LD10 against the L1D when it comes to runtimes and output? I know the LD10 has a lower low mode, but does it have a longer runtime in low mode also?
The L1D can go about 20 hours on an alkaline battery, and the LD10 can go about 20 hours on an eneloop. I guess that means that the LD10 draws a little less current, but it looks like there should be a bigger difference when the LD10 is about half the brightness of the L1D.
It had been much easier if someone had made a proper comparison review with the LD10 including runtimes.
And then there's the "turbo" mode. From what i have seen the LD10 will go nearly one hour on a eneloop, but the L1D (Q5) lasts 1 hour and 44 minutes on a 2650mah cell.
My L1D rebel 100 can put out the same brightness for 2 hours and 30 minutes on a 2650mah cell or about 1 hour and 45 minutes on an eneloop . That's almost 200% the runtime of the LD10. Is it really THAT much brighter? Or have they downgraded the circuit that badly?
