I too ordered up two 14500s to go with my new L1Dce.Seijin said:Thanks for the reply. I had ordered one today and then come across another thread that questioned whether some protected 14500's would fit or not. I'm glad I made the right purchase then.
It doesn't keep the function selection circuit from working - it just overrides the lower light settings since they kick into direct drive at the higher voltage. This could be fixed but it appears they didn't plan on running these on the higher voltage rechargeables. I'm assuming it would cost more to design the circuit to run in a 1.2 to 4.2 voltage range than the 1.2 to 1.6 v range which is only a boost circuit whereas the other one needs to be able to adjust up OR down.Frank Maddix said:I too ordered up two 14500s to go with my new L1Dce.
You have to be a bit careful I think.
Firstly, they are about 1.5 mm longer than alkalines, so tightening up is *really* tight. You have to stop thinking about the pressure on the PCB contact.
Secondly, the plastic shrouding extends quite a bit and may have to be trimmed. Thirdly, my 14500's aren't the same size. One is about .5 mm longer. Doesn't sound much, but it felt very different when tightening up.
Having said that, it works fine, with the usual bypass effect.
Incidentally, if the controller is being bypassed, how is it that the strobe / SOS functions still work?
chevrofreak said:To get my AW protected 14500 to fit I had to make a copper ring from some thin doorbell wire that was stripped of its insulation. I placed it between the tailcap and body, then removed the head to change out cells. The cell was about 1mm too long, and I didnt want to crush it.
BTW, it performs extremely well on Max with the 14500.
beam_me_up said:dang i just bought the P1D CE and now I think I want this combo instead!
Do you have any beamshots between the two ? Is the L1D a tighter beam?
Seijin said:Received my AW 14500 Li-ion on Friday and it fits perfectly. I appreciate all the advice that was offered. I am very pleased with the performance of this battery and the L1D CE
smknman said:tighten the head before the tail when putting the battery in, that way you can still change modes
It fits, yes and no.
To make sure no extra pressure is required, unscrew the bezel to put it into general mode. This gives you more length.
If you want strobe (turbo mode) then put it into that mode before installing the battery and tail cap. it may be too short still. And the cell will bottom out a bit on the switch retaining ring and the spring will be fully compressed. The tail cap will be very tight because you are smashing the cell basically. Be careful.
YMMV. (battery length and body length vary)
