AnthonyM83
- Joined
- Jan 31, 2007
- Messages
- 7
I'm an EMT looking for a compact flashlight to use on-duty.
Most applications will be short to medium range, such as light directly on a patient's wound while it's being bandaged, an unlit bedroom, or a small area on a sidewalk. Occasionally, long-range when locating an apartment number or a door inside a complex.
I'd like it compact for small holster belt carry or even pocket carry. Since most EMTs don't carry much on their belt, I want to keep it compact and out of the way (partially to prevent getting comments about overpreparedness).
I like L4's long runtime and output, even if less intense after an hour. I especially like it's size...and most probably won't expect the light output from that size.
Strion is a bit bigger, but allows me to recharge, though apparently I can use rechargeables on L4 with lower runtime? Also Strion has a "wider beam" which can be good at scenes to light everyone up when working on an extracation or side of the freeway...but not as bright... And shorter runtime
I'm assuming they're both rugged and resilient. It will probably be dropped a number of times.
Any thoughts on this?
Thank you,
Anthony
Thank you,
Anthony
