LD10 head won't fit LD20 tube?
aau007
I ordered a LD20 tube from lighthound and found out it won't fit my LD10 head and tail. Is there different versions of LD20 tube? The LD20 tube has finer threads. Sent an email to lighthound, do they take returns?
If your LD10 head is newer (i.e. an R4) than your LD20 tube (which may be an earlier than R4 vintage), then yes, it is true - the threads in both the head and tail are square cut in the newer versions (better) and are now not backward compatible with prior generations of the LD10/20 lights.
(Noted in this review)
I was told that the LD10 cannot handle lithium ion batteries that run 3.7v. It looses its low mode on slightly over 1.5v. How well is the LD10 head going to run off 3v?
I am guessing that the threads don't match so people will not lego them and blow the circuit.
Correct me if I am wrong. I thought the LD20 r4 and LD10 r4 uses the same head and tail, just a longer body for the LD20. No?
I think you better confirm that by checking with Fenix before you try it. If 1.7v is too much for low modes on the LD10, then how is 3v not too high?
Easy now boys and girls.
A lot of "I think so" here
The driver on the LD10/20 (yes same head) goes into direct drive somewhere around 3.2v.
You can run 1x Lithium 1.7v in the LD10 with absolutely no loss of modes.
You can run 2x Alkaline or 2x NiMh in the LD20 with no side effects, only when you run 2x 1.7v Lithiums do you run into issues. (3.4v)
Same with 1x 14500 Li-Ion 3.7v in the LD10.
Thread issues are as mentioned above.
I have not seen a LD20 tube for sale with the new thread pattern, my own LD10/20 was made from an older LD10 Q5 and L2D body.
If I remember correctly the clip versions of LD20 and LD10 were the first to have square threads and broke the compatibility.
I've been using my LD10 Q5 head on LD20 body with no ill effects, and the output seems to be the same as the LD20 head on the same body.
My LD10 looses low mode with lithium primaries. Its fine with alkaline or eneloops.
Is there more versions on the LD20? There is the Q5, R4 and now the "Clip" version?
I would say your LD10 is pretty unique and probably broken then.
Normal LD10 heads can run with 2x1.5v=3v and maintain all modes.
Not even close to broken. Do a search on my name and a thread about it will come up. Mine is not even close to being rare. I even contacted 4sevens and they said it was perfectly normal. There was a thread about this less than a week ago.
Could you point me to the thread please?
You have just confused the hell out of me, reading all your posts about the LD20 when we are talking about the LD10.
Both the Quark AA2 and the Fenix LD10 are multi mode 2AA lights.
Incorrect. The LD20 is a 2xAA light, the LD10 is a 1xAA light.
Only when you turn it into a LD20.
(LD20) 2x1.7v = 3.4v = problem
(LD10) 1x1.7v = 1.7v = works fine
I have had problems with my LD10 and LD20 with lithium primaries. Maybe I am remembering wrong, but that is one reason I dropped it from my get home bag. The second reason was the lack of a moon light mode.
The quote about the LD10 being a two cell light is either not mine, or a typo. I have both.
So is there no way I can get a LD20 tube that will fit the R4 head at this point? I tried sending an email to Fenix but they are not answering my email.
