LED Christmas Lights at Wal-Mart
PhotonWrangler
In a handbasket
Canuke said:
I figure it should be possible to make one that is no bigger than a standard travel adapter, and bill it as "double the brightness/flickerfixer" for LED lights.
I've been toying with that idea, having built a smallish one once, but I'm a little worried about the potential liability of a 120vDC converter that could wind up in the hands of someone who doesn't understand the potential danger.
James S
on an island surrounded by reality
would an external box/adaptor/powersupply really be any more dangerous as far as thats concerned than say one of those lamp dimmer boxes? They come with the dimmer on the cord and a regular plug and socket. The label says, incandescent lamps only. If you plug the TV into one and it burns out they don't blame the dimmer, they blame the user :)
The lights really do look good on a DC supply. even without the cap, a full wave bridge rectifier reduces the visible flicker by quite a bit. Why can't these companies put an extra 40 cents worth of parts into the plug and just add that, then the bulb count would be correct for the DC output/duty cycle and everything would be great. Seems that future high quality strands probably will do this. The cheap flickery ones will be quite obvious by comparison.
PhotonWrangler
In a handbasket
The problem is less about burning out appliances as it's about someone getting zapped by high voltage DC. It's much harder to let go of a live wire when it's DC because the current flow keeps the muscles contracted in a particular direction. AC gives an individual a better chance of being able to let go.
ledBelly
I see one site that sells this type of light set, and they state you connect up to 125 SETS in series with their "commercial power adapter"!
(see http://www.christmaslightsetc.com/categorydetail.asp?CategoryID=736)
Given that each of their sets contains 25 LEDs, we're talking about 3,125 lights from a single outlet!
I'm interested in creating lighting using large arrays of LEDs, in series-parallel circuits, but this sounds amazing/unlikely! Have any of you successfully connected several sets of your LED Christmas lights in series? And what can this magical "commercial power adapter" be?
