Oh, shoot. I tested a few LEDs days ago, but then forgot to post my findings.
I had two LED emitter to test. One is a Cree XR-E, and the other is a Cree XR-C. I do not know what the flux bins were on either LED, because both were from DX (removed from the flashlight during previous mods), but that will not matter. I do not have an integrating shpere, but I do have a white paper lined box, which gives me great comparative measurements between LEDs. This is what I use to compare different flashlights and LED emitters at various currents.
For my test setup and process, I secured an emitter to an old PIII/P4 heatsink (no fan necessary), then applied 350mA to the LED via a CC/CV labratory power supply. I set the heatsink against my custom light box (positioned the same way every time thanks to a little jig I created), let the LED warm up for 2 minutes at 350mA, then took my lux readings. I would take a reading, turn the PS off, for a few seconds, then turn it back on for a few seconds to take anther reading. I did this three times for every test, although this redundancy did not show any irregularities a single time (but I did it to be safe).
I repeated this process for each test. I made three tests per LED emitter.
-First, I measured the lux from the light box with the original, unharmed LED emitter.
-Next, I carefully pried off the dome by taking the tip of a new standard Exacto knife blade and placing it under the edge of the dome. I carefully pried at the dome and worked my way around. With the dome removed, I checked to make sure that the emitter was still well seated on the heatsink. I placed the modified LED against the lightbox and took my second lux reading.
-Finally, I pried the ring off of the Cree emitter substrate, careful not to destroy the soft silicone material around the die and the bond wires. I took the same Exacto blade and scored the jelly-like silicone around the die (slid it around the inside perimeter of the metal ring). Then I used side-snipping wire cutters to pry the ring off of the emitter substrate. I was less patient here than I used to be. It is better to cut a notch on the ring with a Dremel cutting disk, and use a flat-head screwdriver to pry it off (lower mortality rate this way). I just moved, so I did not want to dig out my Dremel. With the ring removed, I again checked to make sure that the emitter was still well seated on the heatsink. I set the LED back against the lightbox for the last reading. I repeated the three steps for each LED.
XR-C:
Inital lux reading:
109 lux
Removed dome optic:
74 lux (
-28.2% from initial)
Removed dome support ring:
55 lux (-49.5% from initial)
XR-E:
Inital lux reading:
142 lux
Removed dome optic:
10 lux (
-25.4% from initial)
98 lux (-30.9% from initial)
Again, these lux readings are not exactly like "lumens". I never had a chance to calibrate my box to find a coefficient to match it with a lumen value.
So, you can see that the XR-C suffered more from the modification than the XR-E. I am concerned that I damaged the gummy silicone on the XR-C when I removed the ring, so I could have disturbed the phosphor layer. I am very confident with the results of the XR-E, however. The important part of this experiment (and the topic of this thread) is the light reduction after removing the dome, so removing the ring is not as relevent. The die size could have been a contributing factor to all of this as well.
So, someday, I will test this on a Lumileds Rebel. I am searching around for a cheap Earth globe (which uses two cardboard half-spheres) so I can paint the inside the proper glossy white color, then install a better baffle. Then, with this setup, I will then find the coefficient to convert my lux values to lumen values.
Cheers,
-Tony
NOTE: Something odd is going on with the date and time. I think this was why the CPF was temporarily shut back down. It sure is confusing. Oh, I predict that someone with the name of peterthomson will post about his 2D Maglite with Q5 in a apheric lens setup in a post tomorrow (the 13th) at some time between 4pm and 4:30pm....
