Hi!
I am quite a newbie with electronics (and its terms) and maybe therefore I didn't find old threats related this problem even if I'm quite sure that this has been discussed before.
I am building a device where I need bright light in very short pulses (something like 1 millisecond on and 10 seconds off) and I am using LEDs (SSC P4). Now I am looking for driver for leds (one driver for each led). With the driver I want to control (maybe with a potentiometer) the forward current from ~700mA to ~2000mA and willingly more. The control signal to turn the led on is given external via (max.) 5V/0V logical signal and the response should be very fast (not many microseconds). The circuit should also be as small as possible (present circuit is 2cm x 3cm).
I haven't found led drivers that has as high output current. I think that for example MIC2291 (http://www.farnell.com/datasheets/69898.pdf) is quite close but not enough. I think that someone here would know much more from ICs and especially led drivers.
Thank you already in advance.
