purduephotog
- Joined
- Jul 15, 2007
- Messages
- 591
As you saw in an earlier post I was / am trying to find some royal blue CREEs and not having much luck. I did come up with some on Mouser that are being discontinued- but before I plop down the 200$ I'd like just a bit of sanity check here.
Building around the 40W Xitanium device (40$), I'd like to put 4x of the LedEngin 10W Deep Red ( http://www.mouser.com/Search/Refine.aspx?Ntt=*897LZ440R210 , 32$). Spec is 11.6V, .7A
If I read that right then I'd be wiring the array as 2x2 - 2 in series to get to 24V and then another string in parallel- but that only is 1.4A instead of the 1.7 the unit states.
Will I be over driving the LedEngin Deep reds?
Next I'd pick up 10 or so of these 2.5W Royal Blue (soon to be discontinued: http://www.mouser.com/Search/Refine.aspx?Ntt=*889D32282 ). The specs didn't match up- I eventually found them and they're rated at 3.5/4.0V and 0.8A. That means 6x in series (24V) and 2 strings (12 total). 80 Watts total.
How's my math looking?
Any cheaper drivers? I'd hate to spend so much on this just for a test to find out I could have gone cheaper for this testing.
Thanks in advance-
Jason (lovin his garlic growlight...)
Thanks in advance-
