remuen
Hi
For my outdoor sport activities (mainly running) I use a PEZZL TIKKA headlight with 3 LED. Compared to its size and weight (only 70g with 3 AAA batteries) this tiny headlight is really great. And I can use one set of 3 AAA batteries about 13 - 15 hours which is also quit good. Because it is so light I don't even feel it on my head after a few minutes.
Sometimes I also use a modified Jackstrap headband with 2 ARC AAA flash lights instead the TIKKA. Astonishing, but these 2 ARC's are a bit brighter than the TIKKA with 3 LED's but do have a worse battery runtime of only about 5 hours.
Both the TIKKA and the ARC's are quite well for running if the weather is fine. As I am often in the woods this turns when it is wet and the ground is dark. Under these bad circumstances both solutions give only the minimum of light for running. So what can I do? For these runs I need a headlight because I can not carry a flashlight in the hand. And it must be small an light and bright! Earlier I used a MINI-MAG in the above mentioned headband which was a bad solution because of it's bad beam and it is also not very comfortable to wear. I had to replace the batteries every 3 - 4 hours and the bulb every 15 - 30 hours.
Recently I saw a LUCIDO T61 headlight with 6 LED's and an additional halogon bulb. I wouldn't need this halogen bulb (or only on rare occassions) because of its power consumption and the lifetime of the bulb. So only the 6 LED light is interesting me.
Has somebody already used this headlight or has made a review on it or does know where I can find a such review? I have some questions about the Lucido T61:
- The Lucido has about double the weight of the TIKKA but uses a separate battery case. How is it to wear?
- How is the brightness compared to the TIKKA or to my 2 ARC LE solution?
- Does someone have have pic's of the different beams?
- What is the real battery runtime with 6 LED's (that means the time with a useable light for outdoor activities like running)?
- How is the quality of this headlight?
Thanks for your help
