Re: wow gold6
HalfMan is a troll. Plain and simple. He's the semi self appointed guru of this board, who thinks he knows everything about all types of lighting and wants everyone else to bow down at his feet and learn from him. I for one will not bow down.
As to your story of the Polish lamp factory, I remember 25+ years ago seeing lamps from Poland that were pretty rugged, and they would last forever.
Greta, my apologies in advance, but I will not tolerate LightDoctor's attitude.
LightDoctor, I have likely forgot more about lighting in the last week than you will ever know and unlike you, I don't give myself a sycophant title like LightDoctor to try to garner attention for myself when you have, being objectively based on your posts, little real knowledge about Lighting.
It is one thing to disagree with postings, but when one willingly posts and defends what is erroneous information, that is trolling and to that end, as CoveAxe has pointed out, GregP507 has posted grossly inaccurate information which he (and you) are defending. Keep in mind that Greg opened up a 6 year old thread to make his assertions.
So, I will attack the post, not the poster (but CoveAxe has already covered this pretty well) .....
" I think one of the greatest engineering challenges in recent years has been how to shorten the life of an LED emitter. Normally, they are expected to last for decades, but as a business model, longevity is a money-loser for a manufacturer. At the outset of a new technology, the high price and steady adoption-rate can provide a healthy revenue-stream, but as competition cuts in, and the consumer saturation-point comes nearer, those revenue-streams begin to dry up."
- That you think this is fine, but it is completely wrong and there is nothing to support your claim. Lumileds, Cree, and Nichia have consistently pushed up their power end lumen density AND at the same time pushed the maximum temperature for lumen maintenance WHILE also improving the color stability of their products. When mid-power packages came out such as 5630, you would be hard pressed to get to 50,000 hours at 75C junction and 65mA. Now Nichia, Samsung, LG and others will support 125+ mA, at 85C solder point temperature and hit 75-100K+ hours
" When the incandescent light-bulb was introduced by Thomas Edison, the vacuum-tube design was nearly fool-proof. Nearly everyone has heard of the electric light bulb that has been burning in a California firehouse for over a century, and in fact, the same technology used in radio vacuum tubes means that quite often those tubes are still working perfectly after 80-90 years."
- And there are electric heaters (which is what a bulb is when ran at low power) that have lasted that long as well. It is well known and proven that incandescent bulb life is proportional to the 12th power of the voltage applied. What that means is that if you take a bulb designed for 230V and use it at 120V, that if designed for a 1000H life, that it will last about 300 years. There is no magic or amazing design, just using the bulb as a heater ... not really a bulb. Sure it puts out light, but it is pretty ineffective as a lighting appliance. Now if you know nothing about incandescent bulbs, this may appear as some sort of magic and you may buy easily into conspiracy theories, but if you do know about them, you know this is just basic physics.
- The same would go for your Polish bulbs. It has never been difficult to make an incandescent bulb last, just making one that lasts that is also efficient. As the consumer mind-set was for a certain lumen output for a given bulb outside the Iron Curtain, no doubt that is the direction the factory was pushed. Given under the Iron Curtain that retail supply chain was very flaky, you would have wanted something that lasted, even if it was wasteful as getting replacements was difficult. Then when you add the instability of the electrical grid, you would certainly want a more rugged service bulb. However, if you wanted to sell them to "Westerners", you needed to hit a certain lumens/watt for mass-market, otherwise you were a nice rough service bulb ..... which are less efficient ... which is primarily how they achieve long life. The additional filament supports are for vibration tolerance.
" Fluorescent-tube technology is nearly as old, and these as well, have seen their longevity decrease substantially as well. I'm not sure exactly how this planned-obsolescence was achieved, but I suspect it has something to do with allowing the slow infusion of oxygen through the base of the bulb. "
- Again, a ridiculously inaccurate statement. Fluorescent tubes used to last 10,000 hours (if you were lucky), and experience somewhat significant lumen depreciation over their life. Sure some lasted longer, but on average, they were useless pretty close to 10,000 hours.
- A pretty standard T8 lasts 20,000 hours and achieved 90-95% lumen maintenance over that time.
- 40000, 60000 and now even 80,000 hour tubes are available and they keep to that same 90-95% lumen maintenance over life. In addition to that, they have excellent color stability and efficiency has been maintained or improved
"Since LED lighting is a robust solid-state technology, I suspect the weak-points will have to be engineered in the driver circuitry, which in itself is quite robust. Possible weak-points are electrolytic capacitors and thermal heat dissipation. If the capacitors are allowed to degrade, and/or the temperature of the circuit is high, it may lead to earlier failure. i suspect it won't be long before we see LED lighting with a service-life similar to that of incandescent or CFL bulbs."
- Actually for cheap bulbs and lights, the trend is to pretty much eliminate the driver completely and the inherent failure point which pretty much throws your planned obsolescence argument out
- As well, most recent bulb designs like the slim-style and 4Flow almost completely decouple the heat of the LEDs from the driver increasing driver life. However, yes some suppliers have reduced warranties (and the associated carrying costs) because frankly at the price points, customers are not as concerned about 10 year life as they once were.
- On top of all this, standard driver technology and integration has improved (as well as Chinese MFG quality), hence the total number of components has gone down and the MTBF has gone up.
- In the commercial space, 5 year warranties are starting to be replaced by 7 and 10 year warranties. To support those warranties, improvements in design and components do need to be made.
Now GregP507 and LightDoctor, if you would like to provide some verifiable proof of your assertions, not just unsupported anecdotes, then the smart members of CPF will no doubt keep an open mind. However, if you cannot support your hypothesis, then I would put forward that it is not ethical to mislead people as CPF is viewed at least within our community as a good resource.
